您现在的位置: 365建站网 > 365学习 > Adding new feature about the URL suffix definition of an App
文章来源:365jz.com     点击数:146    更新时间:2009-10-14 10:50   参与评论
You know, Uliweb uses expose() to define url, for example:
@expose('/index')
But when you want to change the url suffix for an App, you should edit every views file(of cause you can use static urls.py appoach, but I won't talk about it now). Fox example how to change '/wiki/*' to '/mywiki/*'? So I add this new feature to Uliweb, so that you can define the URL suffix for an App, just adding an entry to URL session, for example:
[URL]
wiki = '/wiki'
If you didn't define an entry for wiki app, all urls in wiki app won't be changed at all. But if you define wiki='/wiki' in settings, all urls in wiki app will be added '/wiki' automatically, even though the urls is started with '/'. So '/index' will be converted to '/wiki/index'. So for above problem, you can just change wiki='/mywiki'.
And the entry key will be the appname, it's the same with app module name, for example: uliweb.contrib.admin, etc.
So in this feature, you can easily change an app URL suffix.
发表评论 (146人查看2条评论)
