您现在的位置: 365建站网 > 建站教程 > 微信公众平台开发 > 5.3.1自动缓存与更新Access Token
此节有 588 人学习过     参与评论
由于Access Token有效期只有7200秒,而每天调用获取的次数只有2000次,所以需要将Access Token进行缓存来保证不触发超过最大调用次数。另外在微信公众平台中,绝大多数高级接口都需要Access Token授权才能进行调用,开发者需要使用中控服务器统一进行缓存与更新,以避免各自刷新而混乱。
下面代码使用缓存来保存Access Token并在3600秒之后自动更新。
 1 class class_weixin
 2 {
 3     var $appid = APPID;
 4     var $appsecret = APPSECRET;
 5
 6     //构造函数,获取Access Token
 7     public function __construct($appid = NULL, $appsecret = NULL)
 8     {
 9         if($appid && $appsecret){
10             $this->appid = $appid;
11             $this->appsecret = $appsecret;
12         }
13
14         //方法1. 缓存形式
15         if (isset($_SERVER['HTTP_APPNAME'])){  //SAE环境,需要开通memcache
16             $mem = memcache_init();
17         }else {                                //本地环境,需已安装memcache
18             $mem = new Memcache;
19             $mem->connect('localhost', 11211) or die ("Could not connect");
20         }
21         $this->access_token = $mem->get($this->appid);
22         if (!isset($this->access_token) || empty($this->access_token)){
23             $url = "https://api.weixin.qq.com/cgi-bin/token?grant_type=client_credential&appid=".$this->appid."&secret=".$this->appsecret;
24             $res = $this->http_request($url);
25             $result = json_decode($res, true);
26             $this->access_token = $result["access_token"];
27             $mem->set($this->appid, $this->access_token, 0, 3600);
28         }
29
30         //方法2. 本地写入
31         $res = file_get_contents('access_token.json');
32         $result = json_decode($res, true);
33         $this->expires_time = $result["expires_time"];
34         $this->access_token = $result["access_token"];
35
36         if (time() > ($this->expires_time + 3600)){
37             $url = "https://api.weixin.qq.com/cgi-bin/token?grant_type=client_credential&appid=".$this->appid."&secret=".$this->appsecret;
38             $res = $this->http_request($url);
39             $result = json_decode($res, true);
40             $this->access_token = $result["access_token"];
41             $this->expires_time = time();
42             file_put_contents('access_token.json', '{"access_token": "'.$this->access_token.'", "expires_time": '.$this->expires_time.'}');
43         }
44     }
45
46     protected function http_request($url, $data = null)
47     {
48         $curl = curl_init();
49         curl_setopt($curl, CURLOPT_URL, $url);
50         curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, FALSE);
51         curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, FALSE);
52         if (!empty($data)){
53             curl_setopt($curl, CURLOPT_POST, 1);
54             curl_setopt($curl, CURLOPT_POSTFIELDS, $data);
55         }
56         curl_setopt($curl, CURLOPT_RETURNTRANSFER, TRUE);
57         $output = curl_exec($curl);
58         curl_close($curl);
59         return $output;
60     }
61 }
上面代码中,定义了一个类class_weixin,在类的构造函数中来更新并缓存Access Token,该函数介绍使用了两种方法。
方法一:使用memcache缓存的方法,首先对memcache进行初始化(第15行~第22行),然后读取缓存中的Access Token值(第21行),如果该值不存在或者为空值(第22行),则重新接口获取(第23行~第26行),并将值存在缓存中同时设置过期时间为3600秒(第27行)。
方法二:使用本地文件读写的方式,首先读取文件access_token.json中的值并将文件中的JSON格式字符串进行编码转成数组(第31行~第34行),并将文件中access_token和expires_time值保存到this对象中,然后判断上次保存的时间距离现在是否已超过3600秒(第36行),如果已经超过则重新调用接口获取(第37行~第41行),并将Access Token和时间更新到文件access_token.json中(第42行)。
最后,类中定义了一个protected型函数http_request,该函数使用curl实现向微信公众平台接口以get或post方式请求数据,几乎适用于所有微信接口数据的访问及提交。
如果读者在使用方法二的时候不能自动创建文件或者抛出语法错误,那么可以自己在同一级目录下先创建一个access_token.json的文件,并把以下初始内容保存在该文件中。
    "access_token":"abcdefghijklnm",
    "expires_time":1166327133
发表评论 (588人查看0条评论)
微信公众平台开发目录
