您现在的位置: 365建站网 > 建站教程 > 微信公众平台开发 > 6.1.2查询所有标签
6.1.2查询所有标签
此节有 235 人学习过     参与评论
查询所有标签的接口如下:
https://api.weixin.qq.com/cgi-bin/tags/get?access_token=ACCESS_TOKEN
该接口的核心代码实现如下:
 1 $access_token = "-4fPq655nSH7ruHqEIIAxVyDpbRZFL4yPudfMuVhcin5PorYwWiTL7RZNuNlsSw_z_MDK5HCd4IKP0VpPBSLID41kWMOKvT1OBXvgt2UjeG1hZhdBuTF9DpG0XcMAG35ZAVjAIALMH";
 2
 3 $url = "https://api.weixin.qq.com/cgi-bin/tags/get?access_token=$access_token";
 4 $result = https_request($url);
 5 var_dump($result);
 6 function https_request($url, $data = null)
 7 {
 8     $curl = curl_init();
 9     curl_setopt($curl, CURLOPT_URL, $url);
10     curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, FALSE);
11     curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, FALSE);
12     if (!empty($data)){
13         curl_setopt($curl, CURLOPT_POST, 1);
14         curl_setopt($curl, CURLOPT_POSTFIELDS, $data);
15     }
16     curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
17     $output = curl_exec($curl);
18     curl_close($curl);
19     return $output;
20 }
上述代码执行后,返回如下:
    "tags":[
            "id":2,
            "name":"星标组",
            "count":2
            "id":101,
            "name":"商家",
            "count":24
            "id":102,
            "name":"分公司",
            "count":2
            "id":103,
            "name":"顾客",
            "count":23
            "id":104,
            "name":"广东",
            "count":0
            "id":105,
            "name":"深圳",
            "count":0
上述返回结果的参数说明如表6-3所示:
表6-3查询所有标签结果参数说明
发表评论 (235人查看0条评论)
微信公众平台开发目录
