您现在的位置: 365建站网 > 建站教程 > 微信公众平台开发 > 23.2QQ表情和Emoji表情
23.2QQ表情和Emoji表情
此节有 480 人学习过     参与评论
微信的文字内容发送框里面,有一个笑脸符号 ,点击该笑脸后,可以看到下面有很多表情图标。在使用微信发送信息时,我们可以发送表情。这些表情包括QQ表情和Emoji表情(也叫符号表情)。如图23-2所示。
图23-2微信表情
用户和公众账号都能直接发送或回复相应的QQ表情给对方。微信公众账号回复QQ表情的时候,需要回复相应的表情代码,就能发送出相应的表情。这些表情代码被当作文本消息在微信中转义成图标。QQ表情的相应代码如表23-2所示。
表23-2 QQ表情代码列表
你可以使用如下代码来做QQ表情做替换,这样回复的内容中,如果有相应的词语,就能换成相应的QQ表情。
$face = array(’/::)’,’/::~’,’/::B’,’/::|’,’/:8-)’,’/::<’,’/::$’,’/::X’,’/::Z’,’/::’(’,’/::-|’,’/::@’,’/::P’,’/::D’,’/::O’,’/::(’,’/::+’,’/:Cb’,’/::Q’,’/::T’,’/:,@P’,’/:,@-D’,’/::d’,’/:,@o’,’/::g’,’/:|-)’,’/::!’,’/::L’,’/::>’,’/::,@’,’/:,@f’,’/::-S’,’/:?’,’/:,@x’,’/:,@@’,’/::8’,’/:,@!’,’/:!!!’,’/:xx’,’/:bye’,’/:wipe’,’/:dig’,’/:handclap’,’/:&-(’,’/:B-)’,’/:<@’,’/:@>’,’/::-O’,’/:>-|’,’/:P-(’,’/::’|’,’/:X-)’,’/::’,’/:@x’,’/:8’,’/:pd’,’/:’,’/:beer’,’/:basketb’,’/:oo’,’/:coffee’,’/:eat’,’/:pig’,’/:rose’,’/:fade’,’/:showlove’,’/:heart’,’/:break’,’/:cake’,’/:li’,’/:bome’,’/:kn’,’/:footb’,’/:ladybug’,’/:shit’,’/:moon’,’/:sun’,’/:gift’,’/:hug’,’/:strong’,’/:weak’,’/:share’,’/:v’,’/:@)’,’/:jj’,’/:@@’,’/:bad’,’/:lvu’,’/:no’,’/:ok’,’/:love’,’/:’,’/:jump’,’/:shake’,’/:’,’/:circle’,’/:kotow’,’/:turn’,’/:skip’,’/[]’,’/:#-0’,’/[]’,’/:kiss’,’/:<&’,’/:&>’);
$word = array(‘微笑’,‘伤心’,‘美女’,‘发呆’,‘墨镜’,‘哭’,‘羞’,‘哑’,‘睡’,‘哭’,‘囧’,‘怒’,‘调皮’,‘笑’,‘惊讶’,‘难过’,‘酷’,‘汗’,‘抓狂’,‘吐’,‘笑’,‘快乐’,‘奇’,‘傲’,‘饿’,‘累’,‘吓’,‘汗’,‘高兴’,‘闲’,‘努力’,‘骂’,‘疑问’,‘秘密’,‘乱’,‘疯’,‘哀’,‘鬼’,‘打击’,‘bye’,‘汗’,‘抠’,‘鼓掌’,‘糟糕’,‘恶搞’,‘什么’,‘什么’,‘累’,‘看’,‘难过’,‘难过’,‘坏’,‘亲’,‘吓’,‘可怜’,‘刀’,‘水果’,‘酒’,‘篮球’,‘乒乓’,‘咖啡’,‘美食’,‘动物’,‘鲜花’,‘枯’,‘唇’,‘爱’,‘分手’,‘生日’,‘电’,‘炸弹’,‘刀’,‘足球’,‘虫’,‘臭’,‘月亮’,‘太阳’,‘礼物’,‘伙伴’,‘赞’,‘差’,‘握手’,‘优’,‘恭’,‘勾’,‘顶’,‘坏’,‘爱’,‘不’,‘好的’,‘爱’,‘吻’,‘跳’,‘怕’,‘尖叫’,‘圈’,‘拜’,‘回头’,‘跳’,‘天使’,‘激动’,‘舞’,‘吻’,‘瑜伽’,‘太极’);
$content = str_replace($face, $word, $message);
Emoji即表情符号,词义来自日语(えもじ,e-moji,moji在日语中的含义是字符);是由栗田穣崇(ShigetakaKurit)创建的,目前已普遍应用于网络聊天软件中。Emoji表情的一部分如图23-3所示。
图23-3 Emoji表情
Emoji表情包含多种版本,包括Unified、DoCoMo、KDDI、Softbank以及Google,其中Unified是最官方的版本,也是微信中使用的版本。Emoji表情使用16进制代码标记,其符号达700多个之多。各符号名称、含义及其在各种版本下的16进制代码可以参考官方网站,官网地址为:
http://www.unicode.org/~scherer/emoji4unicode/
各图标详细的说明可以从以下地址下载文档。
http://www.unicode.org/~scherer/emoji4unicode/snapshot/emojidata.pdf
也可以在下列网站进行查询:
http://emoji.fangbei.org/
在微信公众平台中,公众账号回复Emoji表情,不能直接回复代码,需要进行ASCII转码,然后将编码以文本消息回复。十六进制转码代码如下:
function utf8_bytes($cp)
    if ($cp > 0x10000){
        # 4 bytes
        return    chr(0xF0 | (($cp & 0x1C0000) >> 18)).
            chr(0x80 | (($cp & 0x3F000) >> 12)).
            chr(0x80 | (($cp & 0xFC0) >> 6)).
            chr(0x80 | ($cp & 0x3F));
    }else if ($cp > 0x800){
        # 3 bytes
        return    chr(0xE0 | (($cp & 0xF000) >> 12)).
    }else if ($cp > 0x80){
        # 2 bytes
        return    chr(0xC0 | (($cp & 0x7C0) >> 6)).
    }else{
        # 1 byte
        return chr($cp);
构造文本消息时,将相应的十六进制做为参数填入转码函数中即可,特别要注意的是,部分表情有两组十六进制代码,比如“中国国旗”,“美国国旗”。需要将两组十六进制都进行转码后拼接,代码实现如下所示:
privatefunctionreceiveText($object)
$keyword = trim($object->Content);
$content = "中国国旗:".utf8_bytes(0x1F1E8).utf8_bytes(0x1F1F3)."\n".
             "美国国旗:".utf8_bytes(0x1F1FA).utf8_bytes(0x1F1F8)."\n".
             "男女牵手:".utf8_bytes(0x1F46B)."\n".
             "仙人掌:".utf8_bytes(0x1F335)."\n".
             "电话机:".utf8_bytes(0x260E)."\n".
             "药丸:".utf8_bytes(0x1F48A);
$result = $this->transmitText($object, $content);
return$result;
上述代码运行后,效果如图23-4所示。
图23-4 微信公众账号回复Emoji表情
同样的,可以在自定义菜单中也设置一个Emoji表情,增强公众号界面的美观性。代码实现如下所示:
require_once('weixin.class.PHP');
$weixin = new class_weixin();
$button[] = array('name' => $weixin->bytes_to_emoji(0x1F4D8)."微信图书",
                  'sub_button' => array(
                                        array('type' => "view",
                                              'name' => "微信开发最佳实践",
                                              'url'  => "http://union.click.jd.com/jdc?d=DoDG82"
$button[] = array('name' => $weixin->bytes_to_emoji(0x1F3E0)."购买代码",
                                        array('type' => 'view',
                                              'name' => $weixin->bytes_to_emoji(0x1F389)."进入购物",
                                              'url'  => "http://mp.weixin.qq.com/bizmall/mallshelf?id=&t=mall/list&biz=MzA5NzM2MTI4OA==&shelf_id=3&showwxpaytitle=1#wechat_redirect"
                                              'name' => $weixin->bytes_to_emoji(0x1F3AF)."我的订单",
                                              'url'  => "http://info.doucube.com/_fbxxjs/order.php"
var_dump($weixin->create_menu($button));
上述代码运行后,菜单效果如图23-5所示。
图23-5带Emoji表情的自定义菜单
发表评论 (480人查看0条评论)
微信公众平台开发目录
